instrument cluster trouble
I have recently converted my car to a stand alone engine management system. At first all gauges worked fine except the tach. So I decided to try to wire in the tach(good Idea). This is where the trouble begins. With the tach now working none of the other gauges work. I have unhooked the tach and the gauges still do not work. And I have even replaced the cluster itself and that did not help either. I do not know what to do if anyone has any info that may help it would be greatly appreciated.
Welcome, sounds like you're going to need some advice!
You're probably going to get a better response on the turbo board. Not many people have experience this specific.
Good luck!
Good luck!
