replacement bulbs in center console gauges?
Does anyone know where you get replacement bulbs for the oil pressure and voltmeter gauges in the center console? It looks to me like the bulb and the socket are a single piece that you replace as a unit. (note I'm not talking about the clock, which uses a round socket and bulb - the ones for oil pressure and voltmeter have a socket that fits into a 6 sided opening on the back of the gauge). Thanks
My 944 should have the same sort of console stuff as your 924S, but I remember that on my clock and oil pressure gauge, the bulb was removable from the plastic socket... I could be mistaken, but while you have it open take another look. The bulbs themselves are available at different places (try paragon), but I haven't found the type where the plastic socket and the bulb are integrated (like for the warning lights by the fuel/temp gauge). Good luck!
