Interesting Engine Technology
this company has been around a long time- i wonder why it has not been picked up?
Imagine if this became the standard for engines- this company would be the next microsoft....
maybe investing a few thousand bucks wouldnt be a bad idea here...
-Randy
-Randy
Seen that before...their problem is bearing and seal longevity at the "cams". And,I'm not sure if those guys have seen a poppet valve engine ever before...because they state " a poppet valve engine cannot open the valves before the piston has passed TDC"...yet almost every single ordinary car engine in the world does it. And,bikes now have rev-limits of 17 000 + rpm as stock...even seen Nissan RB26DET 2.6-litre straight-6 engines doing 14 000 rpm,so it's not the poppet valves that's restricting them,at least. What someone should make,is electronically actuated valve openers...some form of high-speed solenoid that would be 3D-mapped and could give you full,limitless control of the intake and exhaust phases...like a super-VTEC with infinitly adjustable lift/duration. Then you're talking..
^^^ they are working on it. Problem is the instantaneous power demands would burn up a 12 volt system. There is a move in the automotive industry to re-standardize at 48 volts, which may allow this technology to be feasible.
How about instead of electronically opening the valves you use a hydraulic or pneumatic solenoid instead? Same idea and you can run the pump right off the motor.
my understanding is, that the instantaneous current flow would need unrealisticlly heavy gauge wiring. There is not a whole lot of energy being used over all, but it does have to be delivered over an extremely short period of time. One of the other problems was achieving a soft valve closing, the solenoids tended to slam valves into their seats.
The restandardization isnt for the sake of electronic valvetrains, they would just be a beneficiary. The reason for the change is that the current electronics suites (entertainment, navigation, climate control, etc) are reaching the limit of what a 12V automotive generator can supply, current wise.
