Mobil 1 Oil
Originally Posted by Matt H
I use Royal Purple in the BMW on a 15K interval. When I drained it last time it was still fairly clean. I dont know that I would have gone another 10K on it but it looked and felt good. Changing a synthetic oil every 3K is like flushing money down the toilet.
Tom, one part of me says (almost without thinking) follow the manufacturers stated intervals.
It matter more to me in terms of time than mileage. Mileage can be fairly arbitrary, I put more miles on one of my cars in a month than I have on another in 4 years. I guess the answer is it depends.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
For turbocharged cars, I prefer to go with a 5W-50 than a 0W-40 for that extra protection in the upper range. These cars run hot.
As for the change interval, I agree that full synthetic is meant to last longer, but again, in the turbocharged cars the turbine is more susceptible to contaminants in the oil, so this reason alone warrants more frequent changes than in NA cars (5K miles for me). Unless replacing the turbine is in your planned maintenance schedule.
Hey Man
My 83 leaks so much it's like a perpetual oil change, I need to add a qt every 500 miles...there's always a fresh supply. I use dino on the N/A so I don't feel too bad. M1 in the 951 I do yearly at about 5K-7K miles.
The Aurora, GTO, and even my 82 yo dad's Silhouette have an oil life indicator.
According to my cousin at GM he tested the system in different weather conditions, and different driving conditions. He swears by M1, and once told me the oil wore out a lot quicker in the cold weather, and in stop & go traffic. thats according to the indicator, not testing.
He told his daughter that when it reaches zero casually tell him, and he will change it shortly.
It is calibrated for dino and I use M1 in the Aurora. My wife tells me the computer says oil life is low, and I get around to it when it hits zero. The Aurora Northstar takes 8 quarts!
With my legend coupe I changed the M1 every 4k miles, the guy I sold it to does the same thing. it now has about 125k and he says it still runs perfectly.
I think it lasts about 8k in the Aurora according to the indicator. The GTO has an crummy system. after i change the oil I have to turn the key, pump the gas, swing a chicken in a bag, and then it is reset. the computer doesnt tell how much is left like the other cars.
Hey Man
Originally Posted by Tom R.
... my legend coupe I changed the M1 every 4k miles, the guy I sold it to does the same thing. it now has about 125k and he says it still runs perfectly.
What I ment is they improved there older oils. I'm still interesting in finding actually numbers to see what the oil is like at new,5k,10k, and 15k. It would be interesting to see. I know there is one guy that is on the 928 board a lot that knows his oils pretty well. I notice the new oil at work today. The cost is the same as the older red cap ones so it's worth for me. I'm going to just change my oil each year as I only do 5-8k a year at most. Also replacing the filter isn't hard about 5 mins of work.
Even in my TDI, the oil change is 10,000. Read up on the tests done using synthetic in 18 wheelers and running 50,000 between changes. It's rather interesting really how long big rigs are going between changes now.
For my 944, I'll probably change every 8000 or so. IF a VW diesel and BMW engines can make it that long on a CONSERVATIVE side, I think the 944 will be fine. Read up on Amsoil and Synthetic tests - most car manufacturers are recommending 10,000 changes and synthetic oil now.
I read up on amsoil site the test data. It doesn't include the new mobil 1 but has the old one. Yea those 18 wheelers also have a lot of oil in them so it does take longer for it all to go bad. Our 944 types also have a good amount of oil not many cars out there use that much oil in such little engines. Like the Mustangs have anywhere from 4.5 to 6.75qts what I have seen personnal on the 4.6 and 5.0 engines. I like that we have have more oil. Also the number 2 bearing problems we have are mostly from not having the oil to the full marks if cause on the street and on track the long turns with lack of oil (not at full mark) for a period of time will cause the bearing to fail. I'm getting sided tracked here so for now I'm done.
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
I changed to Mobil 1 5W 50 (Gold cap formulation) about 6 months/8K kms ago (about 5K miles for the metrically challenged). When I filled, it was about 2mm over the max line on the dipstick. It's now about 1mm over the max line on the dipstick. I haven't topped it up at all in 6 months of driving. It's also still a golden brown colour. I'm serious -- this stuff appears to be indestructible.
My '89 S2 engine has ~145K kms/87K miles on it. Needless to say I'm impressed with how little oil it is consuming. My '98 Honda Accord, with similar mileage, drinks like a fish by comparision. (Which reminds me, I haven't checked it lately...)
The 1989 S2/Turbo owners book says change oil and filter every 20000 kms or 1 year for the S2, but every 10000 kms for the Turbo. I'll be sticking to the factory guidelines. I'll also be sticking to Mobil 1, at least for the S2.
-Mark
-Mark
Hey Man
Originally Posted by Mark944na86
I changed to Mobil 1 5W 50 (Gold cap formulation) about 6 months/8K kms ago (about 5K miles for the metrically challenged). When I filled, it was about 2mm over the max line on the dipstick. It's now about 1mm over the max line on the dipstick. I haven't topped it up at all in 6 months of driving. It's also still a golden brown colour. I'm serious -- this stuff appears to be indestructible. -Mark
If you want to change is at 15k you should never drive over 3k rpm and only start your car on warm afternoons.... Honda, VW, and other companies have been voiding warranties because their "10k mile oil change" is for grandma drivers. Can you say sludge?
Its bull****. If you wanna drive our cars like theyre meant to be change it every 5k. Oil filters should be changed as soon as 3k. But this debate is stupid because we will never come to a conclusion.
Serge944 said: But this debate is stupid because we will never come to a conclusion.
Example: Serge944, in his recent post, has made a number of assertions:
1. If you want to change is at 15k you should never drive over 3k rpm and only start your car on warm afternoons....
2. Can you say sludge?
3. Its bull****.
4. If you wanna drive our cars like theyre meant to be change it every 5k.
5. Oil filters should be changed as soon as 3k.
3. Its bull****.
Note, I'm not saying that Serge944 is wrong -- he may right on the money, and those fools in Stuttgart are blowin' it out their collective exhausts. However, I think it is fair to say that the case he presents is less than compelling.
It strikes me that some of the attitudes about oil changing etc. are essentially religious in nature, i.e., generally, you can't reason someone out of a position unless they arrived at that position by reason in the first place. I believe in freedom of religion. However, I also believe in freedom _from_ religion.
Serge944, follow your faith, and may your god(s) be with you. Pax vobis.
OTOH, if you have some more compelling arguments you'd like to share, I'd be pleased to entertain them.
-Mark
