Coil wire polarity
Coil wire polarity
Not really porsche specific but how would you go about figuring out which wire on the coil is the positive and which side is negative? I know the porsche coils are labeled but this is for a jeep. I tried putting a meter on the lines and taking a reading as I cranked which theoretically should give me a positive or negative reading which would make the choice easy but I just got positive readings no matter which way I put them on. Thanks in advance.
Disconnect both wires, turn th ekey to RUN and check for a voltage signal in reference to ground. I believe one wire should have 12V on it, this would be the "+" wire. The other wire should not have a voltage signal to ground. Also, the "-" wire usually runs to the "switch" - points, Hall sensor, or DME system, depending on vehicle.
