Can you actually tell if you need a new timing belt by looking at it?
Old 02-17-2005, 08:08 PM
stoked944
stoked944's Avatar
Unhappy Can you actually tell if you need a new timing belt by looking at it?
I know there is a way to do a timing belt check, but i don't know when it was changed last changed. So would checking it even do any good? I should probably just get it done don't you think?
Old 02-17-2005, 08:09 PM
Dave951M
Dave951M's Avatar
Are you going to risk bent valves over a $15 part?
Old 02-17-2005, 08:16 PM
PCA 944
PCA 944's Avatar
I have a similiar dillemma. I bought my 944 nearly a year ago, but its had a broken odometer for at least a year with the previous owner. While I am nearly certian it was rarely driven (the po had a 98' 911), I don't want to risk distroying the engine for a "15 dollar part."
Would the timing belt condition degrade even if the car is rarely (once a week, and only to get engine warm) driven, or not driven at all?
Old 02-17-2005, 08:19 PM
Kelly Chiu
Kelly Chiu's Avatar
yes rubber is dries out and cracks over time... even if its not exposed to UV rays.
Old 02-17-2005, 08:29 PM
Dave951M
Dave951M's Avatar
Yes, time is one of the big enemies of the timing belt, pun intended. The fabled "time capsule" car is a time bomb of seals, belts and hoses that are way past any rational intended service life. Most of the service interval recommendations on timing belts that I've seen are usually XX000miles OR X years. If you do your own work, this is a $70 job (timing and balance shaft belts). You might want to take the same path we did building race cars, when in doubt, throw it out.
Old 02-17-2005, 08:30 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,091 Likes on 1,190 Posts
No
Old 02-17-2005, 08:39 PM
zoxx2004
zoxx2004's Avatar
I was told every 40,000 at first,but unless its a daily driver you will not reach that for a long time.Several porsche machanics told me every 5 years.I just changed mine it had 40,000 -looked perfect.after I changed it, I realized that the tensioner was all the way extended.With no adjustment left-- not good.I do track my car.I will stick to 5 years. ( this is only my experience)
Old 02-17-2005, 08:57 PM
Mike C.
Mike C.'s Avatar
No, no, no!
Old 02-17-2005, 08:59 PM
Porsche-O-Phile
Porsche-O-Phile's Avatar
Exactly. I'd say a visual inspection is better than nothing but not as good as a retensioning, which is not as good as a replacement. If anything looks bad as part of a visual inspection, change it immediately.
Since by the time a belt visually LOOKS bad it's already compromised in terms of its strength I'd say a bad looking belt is a guarantee it's bad, but a good looking belt is not a guarantee it's good.
Old 02-17-2005, 09:52 PM
Burma Shave
Burma Shave's Avatar
If you don't know when or how many miles...do it now. Belt,seals,rollers and waterpump. Do it yourself. $400 or so in parts. I did mine when I first bought it. Take your time(weekend). Great way to get to know your car and not that difficult with some patience and planning.
Old 02-17-2005, 09:54 PM
Mike C.
Mike C.'s Avatar
I second that Burma Shave...
Old 02-17-2005, 10:15 PM
jinx099
jinx099's Avatar
How do you change the belt without changing the valve timing? My belt has about 4k miles and 9 months on it according to the PO, but he also said the last one broke prematurely.
Old 02-17-2005, 10:28 PM
Serge944
Serge944's Avatar
Worn belts will have a glazed look.
Old 02-17-2005, 10:32 PM
KLR
KLR's Avatar
Yes -- if it has cracks, missing teeth, glazing, etc.
Can you tell if you DON'T need a new timing belt by looking at it?
No. Therein lies the rub.
Old 02-17-2005, 11:06 PM
theedge
theedge's Avatar
Clarks garage has a how-to, with pics.
To answer your question, theres several spots through the whole system where they are lined up to certain reference points, and as long as it all stays there and is lined up in the same spots on re-assembly, the timing stays the same.
Quick Reply: Can you actually tell if you need a new timing belt by looking at it?
