Oil pan gasket replacement needed?
Hello everyone!
My oil pan started leaking last week after I replaced the gasket about 3 months ago. It was torqued correctly so I think the gasket just didn't seat properly or slid around.
Anyway, I am about to order the oil pan gasket retainers from MySwiss and I was wondering if I could re-use the gasket? It's just 3 months old and it seems the retainers would prohibit any gasket squish.
So, can I use the old gasket or should just pony up the $50 for a new one?
FYI: for those who don't know about these, here is the link!
https://rennlist.com/forums/showthre...sket+retainers
Nerd Herder
Try retorqing it- (note drain the oil first) back all the bolts off and do the 3x retorque sequence to the spec. If it still leaks- it has compressed too much and time for a new gasket.
This can be done with the crossmember on- get a feel for each torque setting and duplicate on the 2 PITA bolts above the crossmember with an open end.
I used blue loctite on the oil pan bolts when I did the gasket- no bolts have backed out and I have developed no leaks in 2 years (knock on wood.....)
Be quiet Pete...
Be quiet Pete...
Well, I have to take it off anyway. I think the source of a mysterious buzz that comes and goes may be in the pan itself (Baffles?)or the pick up tube.
I ordered the retainers to make the reinstallation easier, but I am debating on whether it is neccesary to replace the gasket since the retainers actually keep the gasket presed in thereby reducing the possibility for leaks.
I would just hate spending another $50 bucks on a gasket if not needed.
Nerd Herder
True- the only time they really leak is when they bulgeout of the mating surfaces- the retainers would make that an almost zero possibility.
I guess I was really lucky on mine- but I took a LOT of time doing the torque sequence. Finger tight 2x, 2Lbs rest. 4lbs rest. then to final setting and recheck twice. Maybe 5 hours.
It went a little like this...
Torque, rest an hour. drink 2 beers. recheck torque rest an hour, drink 2 beers. check again, more beer. Start next torque setting...... Repeat until you pass out at 14FtLbs or case is empty.
Note to self:
Stop by package store - CHECK!
