FUEL LINE FITTING GB feeler........
#31
They flair nicely but require a double flair because they are seamed steel. The harbor freight flaring tool will do double flairs. Do a search and read up about flaring fuel lines. You will find its quite a bit easier than you would think.
You could also hit up Bruce and see if he would be up for modifying a batch of H.F. flaring tools. Maybe even put together a tutorial with where to buy what.
#32
So, would you install some kind of fitting where the crimp in the wheel well is? Or would you replace the entire line. I'd think somebody with a flaring tool could just make the 2-3' section where the OEM rubber lines are. Wouldn't this cause some kind of issue as the engine rocks around?...
#33
Defending the Border
Rest In Peace
Rest In Peace
Just talked to Parker local, no news from Ohio (special fittings div).
Zero- The steel line goes to the tank, and yes, the flare/adapter goes in the fender well
#35
Originally Posted by Travis - sflraver
Just get a little hand tubing bender and bend up some custom SS hard line from the tank to the fender well. That way you can get whatever size you want and have complete lines from front to back. Probably be cheaper than the metric to AN adapters.
Oh indecision, it gets me every time.
#36
Is stainless steel tubing like this available anywhere? This sounds like a fun way to spend a day. I'm an electrician, and I've bent so much conduit in my life, that this project looks easy. My lines are all rusty too.
What would you do about the fitting on the FPD? I would probably use some brake hoses/hardware for all of the fittings that I possibly can, seems like the safest way to do it.
#37
And you know what gripes me? Why do commercially available 37 degree flaring tools that will do double flares and/or will do stainless have to be so expensive? I Travis can come up with something more reasonable than $260 I would be tickled pink. Aircraft Spruce has some for around $100.00, but they don't recommend them for stainless, nor will it do double flares as best as I can tell.
#38
#42
I can get the fittings that go into the push lock hose and connect to the FPD. You use the blue push lock hose (same as our kits use). You use a small pipe cutter to cut off the hard lines in the fender well, flair the ends, use AN to push lock hose fittings on the two new flares on the hard lines and one of the ones I have to attach to the FPD. The FPR connection has always been a hose clamp. Its not too hard, its just getting someone to modify the cheap 45 flair tools to make a 37.
#44
Rest In Peace
Rest In Peace
UPDATE
Local Parker finially called back and prices are about $35 a fitting, for quantity <15. I'm still waiting for a quote from Eaton/Aeroquip.
#45
Originally Posted by ibkevin
UPDATE
