Sourcing clutch... Is this EVERYTHING?
I'm trying to get serious about ordering stuff for the car before the winters over.... Range rover is almost done (just in time for spring... ) .
http://cgi.ebay.com/ebaymotors/ws/eB...category=33730
Is this a good deal, and is there anything else that I would need to buy for a clutch job? I'm planning on doing rear seals too. What else do i need and is there a better price to get it for somewhere else?
The price is pretty good. That is what I was going to get for my N/A.
You will also need clutch release fork bearings (x2) and a pilot bearing. Rear main seal if you need it as well.
That's all I'm aware of.
You're going to want to buy pressure plate to flywheel bolts. If you plan to remove the flywheel, replace those bolts as well. As I understand it, these bolts are designed to stretch when torqued, so they shouldn't be reused. Mine were stretched when I removed them.
There is also a small chrome plated guide that is worth replacing since it's cheap.
You might want to check out Pelican's site - the have a very complete kit.
Also, the Ebay buy it now price is the same as the starting bid. What's up with that?
It's just like simply selling the item in an EBay store, but it gets listed with the auctions as well. Good point on the hardware kit. Lindsey has it for around $60, and I think it includes most of the little bits.
do pilot bearings and clutch fork bearings come in some of the more pricey kits? Is it more worth going for a more expensive kit with them with it, or is it cheaper to do this and buy them? I'll do some shopping around I guess.
