High Current Draw With Key Off - is .48mA too high?
(WITH THE ENGINE OFF) - Using a DC AMP meter, I pull the Negative terminal off of the battery, put the positive (red) probe on the negative cable and the Negative (black) probe on the negative terminal, Begin with the highest setting on the meter (usually 10 amps) and work down till you are in the proper range.
Hey Man
Originally Posted by bearone
with the neg cable removed isn't it an imcomplete circuit with no draw of current?
Originally Posted by 2Tight
The ammeter completes the circuit; personally I use a shunt to protect my multimeter from high current 'surprises'
On the 85.5 and later cars the door switch controls the window relay. When you shut off the car the window relay stays active unit you open the driver's door. If the door switch does not work then the relay stays active and will drain the battery in a little over a week. I had this problem on my 951.
Hey Man
Originally Posted by dme
If your getting better then 10 amps draw with everything off then there is a real problem.
Always make sure to follow the directions on how to read current as stated. Reading current is NOT the same as reading voltage. If you try to read current the same as you read voltage, you'll either create big sparks and scare the **** out of you, or you'll fry the meter, or who knows what else.
Perfect timing - I need to check mine.
I just had an immobiliser fitted (damned UK insurance companies!) and it flattened my battery within a week. Prior to that it would sit 3-4 weeks and start without hesitation (battery now 18 months old).
They definitely mucked up the wiring as the courtesy light does not come on when the drivers door opens. It goes back to the shop on Wednesday so wish me luck.
I understand the difference between measuring current and voltage but please describe a shunt. Is it something you buy or lash together?
Chris
Chris
Take keys out of the ignition.
Ttake the negative wire off the battery. Connect your ammeter in series from the battery cable to the negative post on the battery. Make sure you have your meter set to the appropriate scale or you'll blow out the meter and/or the fuses.
To check for current draw circuit by circuit, open the fuse box and place your ammeter where it's readable. Run a test lead (wire with clamps on both ends) from the negative terminal of the battery accross the car and clip it to the positive lead of your ammeter. then, run another lead from the negative lead of your ammeter to back to the battery cable.
Then, pull fuses one by one and see when the current draw goes down. The pulled fuse that reduces the current draw indicates which circuit is pulling the current.
Looking up which fuse the circuit is for can give you an idea of what to troubleshoot for shorts, etc. in my case, it was fuse 39, which is the radio.
You would then need to start working your way through the wiring harness, etc. to see where a short is or what is causing the current draw.
