HP at various boost levels?
Does anyone know of where I can find a chart or results where someone has done a dyno on a stock engine at various boost levels? Trying to see where I stand with a stock engine. Thanks, TT
On a bone stock car with a K26-6 I have seen most cars in the 190 range, a few in the 200 range and one or two at 210. Beyond the stock boost level it just depends on the mods.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
I know 190 is VERY common to get but it also depends on how people take care of the car. If you always keep up on everything when it needs replaced, then depending on miles I would say with a stock you should be between 190-195 rwhp. Now you just can't add psi to get more HP you know you need to tune it, so depending on where you get the chips will depend on how much HP per PSI.
About 185-190rwhp is the most common. I've got a stock 951 dyno-chart on my 951 RacerX website. Also got another one on my GURU Forums under "Dyno Charts". But that one had an LBE, so it's got more power than bone-stock 951 due to more high-RPM boost than stock (which tends to drop off by 4-5psi)
