Front suspension
Front suspension
I have had a knocking noise in my front end when I turn a corner. It sounds like the noise that you get when a front sway bar bushing is worn out. But I recently replaced all front suspension parts. Yesterday I was under the hood and I decided to see if the upper strut nuts were tight. I put a socket on the center nut, on the top middle of the strut, and it turned easily. I tried to tighten it, but it seemed to turn on the threaded shaft. Haynes manual isn't helpful. Is it supposed to turn easily. If not, how do I tighten it?
1987 924S
Boge struts (new)
1987 924S
Boge struts (new)
It turns because it is connected to the shock absorbers shaft which itself spins freely by design. Tightening it can be tricky, as you cant damage the shaft in any way. Im sure someone has a tip, if that is the problem.
In the top of the Boge struts isn't there normally an alan key hole ? I'm sure there was on mine befor I changed them for Konis. To tighten use a deep dish open or closed ended spanner/wrench and use the correct sized alan key to stop the strut turning.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
Originally Posted by shmucklebuckle
Wow, that's a cool...tool. Never seen one before.
