who said torsion bars were difficult?
Old 01-18-2005 | 02:16 PM
hosrom_951's Avatar
hosrom_951
UAE Rennlist Ambassador
I always considered replacing those rear bushings, but NO ONE here re-indexes T-bars that's why i stay away from them. Being a student and working at the same time just doesn't give me time at all to tackle such a job.........your lucky
Old 01-18-2005 | 02:26 PM
joseph mitro's Avatar
joseph mitro
Hey Chuck,
I really do appreciate all that you're saying. And the link you provided is what I've used to remove the bars so far. With all the bad things being said, I'm considering not using the Welts, but I can't justify the cost of the polybronze bearings. I'm still ambivalent at this point, but hey, I enjoy working on my car, so it's a nice respite from the daily grind.
Old 01-18-2005 | 02:34 PM
Oddjob's Avatar
Oddjob
Option 4: go with the Kelly Moss Racing setup (if its still available). By far the most expensive but probably also the best. You have to either send them your torsion bar carrier or out source the machining yourself. They install sealed roller bearings (I believe they are tapered) to replace the spring plate bushings. Very trick setup, but again, very expensive. This setup is worthwhile for torsion bar delete cars, and because of machining requirements, not legal for Club Race stock class cars.
Anyway, back to reality......
Old 01-18-2005 | 02:41 PM
Oddjob's Avatar
Oddjob
Done 5 times on 3 different cars: Put in 28mm T-bars, ran two cars T-bar delete with coil overs, reindexed stock bars to ride height for helper coils on two cars. Not anywhere near as bad as some other jobs like a clutch or turbo removal/replacement.
No point in doing the job just to replace bushings. Only replace the bushings if you are reindexing for ride height changes, different T-bars, etc.
Old 01-18-2005 | 03:09 PM
Elephant Chuck's Avatar
Elephant Chuck
Former Vendor
Originally Posted by Zero10
Okay, stupid question time.
Did you find the bushings needed replacement? How could you tell?...
How do the original stock rubber bushings hold up? Maybe I should replace with those.
You can get a sense of bushing status without taking the car apart. Look where the spring plate protrudes though the cover plate hole. The spring plate tube should be concentric in the cover plate hole.
If the spring plate tube is not centered in the cover plate hole, your bushings are done. When the tube drifts off center, it move up towards the top of the hole. In extreme cases, the tube will actually contact the spring plate cover.
The factory rubber bushings "cold flow" under the weight of the car. This happens over time even if the car is not driven.
Old 01-18-2005 | 03:36 PM
hosrom_951's Avatar
hosrom_951
Jim B.: I got the hight set-up, those shocks need replacement soon (not relevant though), other than that, do the t-bars themselves need repalcing after time?
Old 01-18-2005 | 03:55 PM
Elephant Chuck
Former Vendor
Here is a picture of bushings off the car showing the cold flow. In this case the car is 18 years old with about 80k miles,
The digital readout is partly obscured but you can read the scale. One side of the bushing is 16mm the other is 20.22mm. It is supposed to be round / equal thickness. With the weight of the vehicle the difference would be even greater.
Legoland951's Avatar
Legoland951
Try replacing the bushings with delrin or polyurathane. Taking the old stuff off is loads and hours of fun by itself.
Old 01-18-2005 | 04:02 PM
Oddjob's Avatar
Oddjob
You could get into a lot of materials theory here about fatique, endurance, strength/strain, etc, but for our application, I would say, no - torsion bars will not wear out and you do not need to replace them as a maintenance item.
Old 01-18-2005 | 05:13 PM
joseph mitro
ok, here's another question (inspired by shmark's comment on the first page) - anybody tapped the spring plate carrier for a Zerk fitting so you can grease the bushings with bushing grease at various intervals?
Old 01-18-2005 | 05:47 PM
M758's Avatar
M758
Originally Posted by joseph mitro
M758 - does it help to have bushing grease to keep them from squeeking?
No really,
I greased mine when i installed them, but notice squeaks on warm up/ cool down laps. I don't notice all the time and never during racing or hot laps.
The bad news about my car is have helmet on, window's open and am not focused on it. The good news is that without an interior most noise is amplified and I have a relativly quiet exhaust.
Old 01-18-2005 | 09:22 PM
shmark's Avatar
shmark
This is common in the 914 world, adding a zerk fitting and greasing them regularly. Those that have done it say it works well but I chose not to. Doh! The only thing you have to do is slot the bushings to give the grease somewhere to flow.
Old 01-18-2005 | 09:24 PM
shmark's Avatar
shmark
Sure it is. You can have a BBQ!
http://members.rennlist.com/mlitherland/bbq.jpg
914 obviously, but getting them off was absolute cake.
Old 01-18-2005 | 11:24 PM
Legoland951
I tried a torch and caught on fire. It stunk up the whole neighborhood and I put it out because I don't want to get cancer or give my neighbors cancer. 944 may have more rubber too compared to a 914.
Old 01-19-2005 | 12:09 AM
Elephant Chuck
Former Vendor
It's easy to get the rubber bushings off if you use the right technique. Check here to see the easy method.
Quick Reply: who said torsion bars were difficult?
