Leda coil over
I am in the process of installing Leda coil overs on my 968 and need some help with the best orientation. I have read where sometimes the springs will rub against the body of the car. Should I install the shocks upright with the springs on the upper half or is it better to install the shock upside down with the springs on the lower half? I plan on using the lower shock mounts from Racer"s Edge either way. Thanks.
Win
Win
I assume your talking about the rear coil-overs, I would recommend installing them upside down if possible, as for the rubbing against the car I don't know, I have Koni 3012s installed upside down on my S2, I only have a little rubbing of the springs against the shock itself not the car.
