The Door is OPEN!
Got Nothin'
The Door is OPEN!
OK I have the door open. But I ended up taking out the window glass.
Does anyone have a written procedure for reinstalling the glass? Where should the window be? Up? Down? I see the rollers and the tracks, but can't seem to get the front one to engage. Any BTDT? Thanks
Its easiest to start with the channel all the way down and then slide the glass in and place it in the channel.
Regards,
Regards,
How long has it been since that door has been open?
Sorry I have not been able to help. My car has been in pieces for the last two weeks. I have been in 944 hell myself.
My wifes 944 is also acting up.
On top of that my pool contractor wants me to remove my fence and part of my screen incloser this weekend.
My remaining problem with my S is that I have an injector that wants to spray fuel everywhere.
My wifes N/A is intermitantly acting like it is not getting spark, or fuel, or the engine is sufficating.
My Jeep (the fall back car, when the 944 is broke) has a bearing about to sieze. I have not had time to check. I will probally find out when the water pump dies.
OO well it could be worse. It could be 10 degrees outside.
Althougth with this cold front. I don't know, 65 degrees was pretty cold today
Got Nothin'
Success! The door is all put back together, and everything works! Sometimes, taking a night off from a project is a good thing.
Seventh - If you need any help, let me know....my next task is to change out a tie rod assembly, but not for a few weeks...I am actually going to drive the car to work this week!
