how do I take off my sunroof??
Assuming you are just trying to lift the sunroof panel off and are not wanting to remove the whole assembly, here's the procedure:
1) Put the ignition key in position 1. This is only 'tricky' part, you just turn the key one click clockwise, it's not always real obvious that you're in the right position.
2) Push the 'Up' sunroof button. This will retract the lifting arms into the roof. This is counter intuitive but with the key in position 1 they go in, not out.
3) Unlatch the two clips on the front edge of the sunroof.
4) Lift the panel out. It's doable by yourself, much easier if you have help.
5) Enjoy your motoring al fresco!
- Greg
- Greg
thank you very much....I didnt ask before because I thought it would have been much easier. Yesterday was a very sunny day in the Seattle area and it would have been nice to have a open roof. Thanks again.
