Sounds like popcorn
I changed my cam tower to head gasket today and now even though the engine runs smooth and has power there is this popcorn sound. The normal engine sound pretty much drowns it out a 3,000+ rpm.
So what could this be? Did I trash my car?
The Hoffinator
i wouldnt run it til you have it checked out. better to be safe than sorry. does it sound like exhaust popping or internals mettal crunching popping etc?
well I did have a bolt fall in as I was removing it but I fished that out. Maybe the washer got left in. I can check easily enough tomorrow.
UAE Rennlist Ambassador
When you replaced those 4 new ones, did you soak them in oil for a while BEFORE you installed them?
The manual states that if the tappets fall, them you should mark which one goes where and soak them in oil for a while before installing them. I guess that applies to new ones as well.
Mark: the manual states that you soak tappets once they are removed, otherwise it would take longer for them to get lubricated (or something like that).
How long have they been noisy now?
The popcorn wouldn't damage the paint if he used butter
Just this evening I ran it at idle perhaps 10 - 15 minutes total while checking different things and then starting itup again. I dont get the sound when i disconnect the coil and it just cranks. Im not sure if that is relevant though. I then drove not even 5 minutes home/
Check the plugs. When you pulled the cam-tower, some of the spark-plug wires may have gotten damaged, leading to one cylinder running lean and detonating.
hmm - well that would explain no noise when just cranking right? I will check that. I was going to change the wires anyway. Problem is it was late and I was so tired that as I tried to put the beru connector on the kingsbourne set I pulled the screw end off the wire - dang it.
Administrator - "Tyson"
