*UPDATE* (X-Post) Not Happy (Brakes)-Part 2
#31
"I bled the system when my uncle was pressing on the brakes and i attached a small hose onto the bleeder screw, and kept on opening the screw untill the fluid in the hose turned from yellowish to blue w/o bubbles."
"Anyways, im doing the old-fashioned way of bleeding the system tomorrow, will let you know on how that ends (good i hope)."
What step-by-step procedure are you and your uncle using? You have to be careful with the bleed-scerw because you can actually suck air in through the threads.
#32
UAE Rennlist Ambassador
Dan: He pumps the pedal a fee times, then when he presses and holds down the brakes, i open the bleed screw and fluid gushed through the tube and doesn't flow back. I use the tube to see air bubble.
Update: It was foggy and cold this morning, brakes felts like $hit!!!! almost crashes twice near the office
