Hard warm starting after rebuilding injectors
This is weird,
I installed a set of cleaned and flow checked injectors and the car runs great.
Cold starts instantly ( when below 40 degrees or so)
Hot starts instantly ( as long as it hasnt set for an hour or so)
But starting when the temp is 60 degrees or so, or after it has set for more than an hour or two takes about 5 seconds of cranking , then it fires and runs fine.
Fuel pressure leak down is within spec.
Any Ideas???
Any Ideas???
Yep, fires right up. I'v tried 2 different FPR's that I have just to see...no difference.
I'll hook up a gauge again tomorrow and check leak down again.
