Turbo's aren't interference design???
Old 12-04-2004, 12:27 PM
  #31
AndyK
AndyK's Avatar
Interesting to note that my dad's POS 90 Accord has an interference engine. Same for most Hondas. I guess they have a sturdier timing chain, or, are much cheaper to replace if one breaks? Otherwise, you would see similar reviews for used Hondas - "beware the interference designed engine and replace your timing belts regularly"...!
Old 12-04-2004, 12:34 PM
  #32
fezz
fezz's Avatar
Originally Posted by Danno
[b][i]Due to the angle of the valves, I suspect it's going to be a substantial amount. On the 944GTR head, the valves are much more vertical, so they actually fit into the pocket on the piston better...
That's right -look how flat the valves are when you look down into the intake on the head. They enter into the combustion chamber and would intersect the pistons at such a shallow angle the piston cuts would be angled slices across the top of the piston - that would affect the shape of the chamber, compression, performance.
Assuming the interference maintains what is optimum for this engine.
Quick Reply: Turbo's aren't interference design???
