Leaks, Leaks every where!
The 951 has been sitting in the garage for a week. I havent driven it. I go out to the garage and this is what i see......
The puddle on th left is oil...the puddle on the right is coolant. They were not there 3 days ago...and the car hasnt moved. WTF?
Since the car hasnt moved, im guesing the pan gasket? and I was told on the coolant posibly heater control valve?
Nerd Herder
Just marking it's territory.
Check the oil pan gasket for oil seepage. Anti freeze may just be overflow if put away with a full tank and hot..
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
Leaks everywhere? Hey, welcome my world!
Obviously, you need to get under there and locate the leak. You may want to remove the belly pan and leave it removed for awhile -- it'll make it easier to look in and track down the leak. I think something that big should be easy to find.
