Throw out bearing assy??
Ok thanks to everyone so far on helping me replace my clutch!! I have a new KEP pressure plate and throw out bearing but I am unsure how to attach the thick washer on to the snap-ring that holds the bearing?? The snap-ring went right into place but how do you get the larger/thick washer over the snap-ring??
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Hey Man
You have to put the heavy washer on first with the detent facing out. The snap ring goes onto the bearing last and ends up in the detent area of the heavy washer. Sounds like you might have this last step reversed. Should be easy to swap around.
