lurching transmission problem
interesting new problem popped up today. while engaged in gear, any gear, at lower rpms (2000-4000) the car was lurching/jumping forward. this has never happened to this extent before, and it stopped doing it after i came to a stop.
ive had lurching before from starting off into 1st.. if i engaged 1st "wrong" i might get some jumping sometimes.. but very rarely.
so is my clutch just crapping out? torque tube issue? or just bury my head under the sand and hope it never happens again? (i like the last one)
thanks in advance.
thanks in advance.
Is it more of a hesitation problem? Your O2 sensor or AFM may be going out. My car has done that before, and the problem gets better after the engine warms up a little.
Hey, what all have you done already to try to fix this. i just read another thread you posted on this issue. That is the problem with starting new threads on the same problem
