Couple of easy questions?
Old 10-29-2004, 12:35 AM
86 951 Driver
86 951 Driver's Avatar
Talking Couple of easy questions?
I found out that I need to fix the reverse lights. I found out that the switch is bad how do I change it and where can I get a new one? Also where is the how to rebuild the shifter for the 944? Thanks ahead of time.
Old 10-29-2004, 12:58 AM
Matt O.
Lifetime Member
Matt O.'s Avatar
Rebuild the shifter?
Old 10-29-2004, 01:04 AM
Techno Duck
Techno Duck's Avatar
I assume you are talking about an automatic?
Dave951M
Dave951M's Avatar
If the pin that connects the shifter to the shift rod is bad, then replace the shifter. If the plastic bearing at the bottom of the shifter is bad, then replace the bearing. IIRC Travis has one.
The rev light switch is mounted on the tranny and just unscrews. Your best bet is somebody like 944ecology for a used one.
Old 10-29-2004, 01:19 AM
tod84944
tod84944's Avatar
I also have a reverse light switch if you need one.
toddandcharity@peoplepc.com
Old 10-29-2004, 04:45 PM
86 951 Driver
I remember reading a while ago about fixing the pin on the shifter by cuttin that one off and putting a harded bolt in there.
Quick Reply: Couple of easy questions?
