can you help me identify these seals?
Nice job. I'll be doing the same thing in a year or two so I appreciate the pics.
I was gonna say something about the oil pressure sender being in the wrong spot but I noticed that on the last page you had moved it to the right spot.
Pete - wow, good eye! i did have it in the wrong spot initially, but moved it when the lower balance shaft support would not fit.
Cruise98 - i placed a crush washer under the oil pickup tube. the factory manual showed a "seal" there so i assumed it was a crush washer. i understand the inability to create oil pressure without the seal, i guess i'll have to remove and reinstall the oil pan to install the clear seal.
BTW - thank you very much for all the help and answers. I do have the correct locations for all the seals determined now.
bump -
can anyone else verify that the clear seal installs on the oil pickup tube? i've already got the oilpan on and would like confirmation before i remove it.
thanks
thanks
