Rusty Rotor Hat blues....
Well, I'm an idiot. When I bought new Zimmerman rotors a few months back, I didn't paint the hats before I had them installed. Now, guess what...RUST! I read that the OE Porsche/Zimmerman rotors are zinc coated to prevent this rust. Not worth double the price though.
Question is, if I decide to sand off the rust, and paint the hats, what am I in for? I remember Damian said rust returned to his 968's rotors after he painted them. Is there a trick, or will rust win out eventually?
I was thinking of using a clear coat of some kind, to keep the nice metallic shine visable between my rim spokes, but a silver would be OKtoo. Anything but the nasty rust that I see every time I look at my nice clean rims!
Thoughts?
Andy
Thoughts?
Andy
Hit them with a spray on rust neutralizer, and then a shot of hi-temp paint ( I used silver on mine). Its worked well for me on previous cars, including my 968.
Regards,
Regards,
Truthfully, I've only had Porsche OEM rotors on my car, but they performed admirably even when they were thinner than the factory recommended wear! (And no cracking or fading either!)
And I don't have to worry about the rotor hats rusting.
Just my $0.42,
-Z.
Do I sand, then prime with some rust inhibitor, then use the high-temp silver/clear, etc?? Or do I spray the anti rust paint on over the rust? Do they make a clear that is high-temp?
Hey Man
I used good old Rustoleum enamel for brush application. I sanded the hat area and vents, solvent wiped, and applied paint with a good brush, no primer. They've remained glossy over 3 years with no bleed through yet. On an all-year driver I'm sure would be harder to keep them rust free, especially back East. BTW paint applied over most of the "rust converters" is not very effective. Good surface prep is the key to longevity.
Hey Man
I used a chromium yellow in the small 4 oz. cans. The Rustoleum canned enamels have very good flow charcteristics, are surprisinly surface tolerant, and lay down smoother than you would think. Mine stayed glossy for years and the brake dust would still wipe right off. Use a good soft natural bristle brush and the brush strokes will not be noticeable unless you're going for concours quality. I would not suggest a clearcoat, the heat will probably cause it to yellow very badly. Again, 95% of coating failures are due to improper surface prep, be sure and get it clean and oil free. If I had my touch-up HVLP gun back then I would have sprayed them probably.
I wouldn't paint the vented part...too much hastle, especially with a spray paint (if I were to go that route).
A clear coat would turn yellow...good call! I figure I'll go with a silver high-temp engine paint or something like that. Or the Rustoleum silver.
1 Post
i used a "caliper" paint in a nice aluminum color, I painted EVERYTHING behind the rim but the spring, the shock, and the actual rotor itself and it's held up for 4 months so far and looks sharp IMO
