Fix one thing, next breaks (rant)
So i just replaced my distributor cap because it melted, the next day, my coolant expansion tank is leaking!!! BLAH!!! just a rant, couldn't it have waited just a few more days???
Dude, ive had it alot worse than that.
my first car, a 1990 saab 9000 turbo (210k miles), these things all happened within 5 months
all engine mounts tore because of age
vacuum leaks sprung up everwhere
shift coupler broke
tranny started whining
signal housing cracked
dash cracked
clutch slave cylinder went bad, required removing entire drivetrain and clutch replacement, took me 2 weeks
window switchpack got water on it and failed
headlight relay failed
computer went bad
top engine mount broke because i forgot to install a bolt, caused fuel rail to bend and engine mount bracket to break, needed to weld bracket because no replacement available and bent fuel rail back, new injectors and new computer
cv boot tore requiring me to replace cv joint/repack
fun fun fun
shift coupler broke
dash cracked
computer went bad
fun fun fun
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
I can beat you to that on my 1984:
-first dead battery
-clutch throwout bearing binded with disc right after putting in new battery
-after new clutch replacement, water pump pisses coolant all over the floor
-after water pump, replaced fuel pressure regulators and damper..
now for the 1986 I have now:
-first a timing belt
-sunroof sh*tted and doesn't work, paid $100 bucks to try to fix it but only got it to unlock in the first ignition key position
-coolant expansion tank leaking and needed replacement so i got a brand new one
-brake master cylinder now leaking and needs replacement
-replaced shocks in front and new springs
-replaced sway bars and a bent sway bar mount.
-repaint
need I say more? I've had the car for 7 months....
-first dead battery
-repaint
Thats it, im gonna post the text file in which I keep track of everything ive done to my car when I get home... Its kinda liek swaggers, but three times longer
This is my list so far, everything is on here I think, except for oddball little things. Damn this thing is long...
New timing belt, balance belt,
alt belt 194768 Feb 13-18 $696.30 @ Park Place
Fog to daytime running lights Mar 10
PPI at SCAN 195511 Mar 12
New battery (DieHard) Mar 16
Changed transaxle oil 195700 Mar 17
Timing belt retension Mar 30
Removed Drivers panel, cleaned April 2nd
power lock and window
New Spark Plug Wires 197240 April 5th
New Throttle Cable 197436 April 7th
New Wiper Blads " April 7th
Console Lid Hinge " April 7th
Installed rebuilt starter 198XXX April 19th
New Tie Rod Assemblies (Both Sides) 198150
New 968 Caster Blocks 198590 May 2nd
Rebuilt Both Ball Joints 198590 May 2nd
New Spark Plugs NKG 198800
First Alignment 199862 May 6th
Provincial Inspection (Passed 1st Time) 199042 May 8th
Changed Oil and Filter 199580 May 16th
Upgraded to SS Fuel Lines 199585 May 17th
Replaced Coolant 199610 May 18th
Final Alignment 199650 May 19th
Rebuilt Right Axle (Both CVs) 199750 May 20th - 21st
Installed: 199982 May 29th - June 5th
Rebuilt waterpump+gasket
New primary thermostat
New resevoir cap
New rad drain plug
Hit 200k miles!! 200000 June 5th
Belts Retensioned by SCAN 200315 June 9th
Installed Turbo TStat 200340 June 10th
Cleaned and Adjusted AFM 200340 June 10th
Replaced fuel filter 200550 June 12th
Replaced brake fluid 200600 June 12-13
Bled all brakes and clutch
Used Prestone Super flush + backflush
kit to flush cooling system 201260 June 22
Removed rad + I/C for cleaning
Used paint thinner, water,
compressed air, degreaser,
and cooling system flush. 201470 June 26-28
New thermo fan sensor, new
heater control valve, new oil
pressure sensor 201871 July 3-4
Oil change and new filter 201871 July 3-4
202000 MILES July 6
New cap and rotor 203151 July 23
Oil change, resealed oil
pressure sensor 203300 July 25
K&N air filter 203546 July 29
New radiator, new rad mounts,
fresh coolant 203560 July 29
Turned all rotors, balanced all
wheels, got injectors cleaned
at NW Fuel 205647 Aug 20
Changed oil 205861 Aug 26
Installed LBE 205959 Aug 28
Installed MSD Blaster2 Coil 206842 Sept 4
207000 MILES 207000 Sept 7
Installed AutoMeter gauge,
boost/vacuum 207250 Sept 11
New Thermostat 207887 Sept 19
New O2 sensor (Bosch 13194) 207887 Sept 19
New Coolant pipe, turbo return
to expansion tank 207887 Sept 19
Fresh coolant, Prestone Orange 207887 Sept 19
Discovered damage to turbo
vanes, intake side 207887 Sept 19
208k miles 208000 Sept 22
Rebuilt shifter with new lever,
bushing, and a brass tube
bushing 208085 Sept 25
Fixed coolant leak, bleed bolt
area. 208270 Sept 27
Fresh coolant 208270 Sept 27
Removed exhaust from downpipe 208550 Oct 1
back for testing (bad mileage
seemed to continue even w/o
cat)
Vacuum Line Overhaul: 208600 Oct 2-3
Deleted Venturi
Deleted CV
Deleted cluster of hardlines
Piped in LBE
Replaced vacuum lines to
FPR, dampner, bypass, fuel
purge
Replaced hoses to OAS,
JBoot -> ISV
Vacuum Line Overhaul CONT: 208655 Oct 4-6AM
New JBoot
New intake manifold gaskets
New DME temp sensor
New(used) block->heater control
valve hardpipe
New(used) thermo vacuum valve
for fuel purge system
Resealed turbo pumpe with RTV
Sealed hardpipe at back of head
with RTV
New coolant
Overhaul CONT: 208693 Oct 6
OIL CHANGE
Replace vacuum lines for
blower control
Found animal nest under blower cover
Replace vacuum line to vacuum
resevoir
Replace vacuum line from
firewall to engine bay
Found out was running on 3
cyls for 3 days, loose
injector connector not vac.
or intake leaks as thought
New throttle valve bolt 208732 Oct 7
New fuel dampner hose 208732 Oct 7
Installed fuel pressure gauge 209850 Oct 17
Installed Greddy Profec A 209912 Oct 18-19
HIT 210000 MILES! 210000 Oct 19, 9:18PM
Bought Welt sways, $520CDN Oct 19
New resevoir cap
New rad drain plug
202000 MILES July 6
cat)
Deleted Venturi
Deleted CV
Piped in LBE
purge
JBoot -> ISV
New JBoot
New DME temp sensor
valve hardpipe
with RTV
New coolant
OIL CHANGE
blower control
resevoir
