Short Shifter installed...ahhh!
My mechanic installed my short shifter from 944Racing. Charged me $80 for the hour labor (well worth it).
When I first tried the shifter, what immediately stood out was the tightness and heftier feel of the shifter--like a much heavier spring was put in there! I shifted into reverse, and thought "this can't be reverse...it must be 4th gear"--because of how short the shifts are now! It was reverse.
Shifting through the gears on the road, I am amazed at how different the car feels! Solid, almost notchy, precise shifts compared to soft, bland shifts before. The shifter action is harder, in a good way. No more shifting with 3 fingers...you need to pop it into gear with a little more umph--click, click!
All I can say is unless you like weak, long throw shifts, get one of these shifters! Way more precise and solid feeling!
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
I just had installed the "Ultimate" shift kit from Speed 6 racing ($225). Includes the shaft and the short lever.
I have mixed opinions: I wish I could have installed one at a time to see the difference between having one without the other - I would recommend this for you! Even though it is more labor costs!
Leverage is sometimes a good thing! You do get better leverage from a taller shaft and I'm guessing better engagement. I'm using a bit more force to shift. My **** is almost engulfed into my shift boot because it's so short.
See pic.
http://forums.rennlist.com/upload/interior_copy20.jpg
See pic.
My biggest gripe thou is that i think i want to go back to the stock shift boot/****. I could replace the shift lever with a stock one and just re-do the 3/8 bolt mod with bushings and locking nut to make it tighter longer.
