ABS Relay Part #??
I posted this in the 951 forum but probably more relevant to post here.
I believe I have found the source of my ABS problem. Essentially, the fuse blows and diode on the ABS relay is shorting to ground. Does anyone know a substitute part # from Bosch or another relay manufacturer?
The original part number is 928 615 124 01. I would like to buy one locally but I need a reference number. The dealer doesn't have one in stock and it's expensive.
Thanks,
David
Thanks,
David
Originally Posted by adrian_jaye
a little hint,
don't substitute it, get the right part
