lower balance shaft cover - help please
Have just installed my engine after a rebuild - runs very well - thanks for everyones help!
There is a leak however - from the lower balance shaft cover. Oil dripping from one of the larger bolts at the rear. I wish it was the upper!!
My question is - can the cover be removed and resealed with the engine and crossmember in place? I see I'll have to take off the exhaust headers to at least get access.
Or will I have to take off the PS pump and the front seal assembly as well?
help appreciated
Spangle
help appreciated
Spangle
I resealed mine about 5 years ago. The only thing I remember having to remove (which I didn't want to remove) was the exhaust headers. On the other hand, I was resealing everything I could but the front seals because of multiple oil leaks. Therefore I had a lot of stuff already out of the way.
you will have to remove the front of the bal shaft housing, which means removing the ps pump etc. The cover itself is sealed with orange case sealer and there is a large o-ring that seals the rear of the housing. Actually, just thinking more about it, you might be able to get away with leaving the front alone, putting the cover back in place over the large o-ring at the front might be a bit tricky but it should be possible, be careful not to trap a bit of the o-ring between the cover and the block.
Good luck, let us know how it works out.
