How to solve SFR short shift rattle?
Rocket Scientist
Hey all. I just installed a sfr ss kit along with my 944 racing one, it shifts amazing. But I am having a lot of rattling. Has anyone corrected this, or know of a way how? I hate rattling with a passion and would like to get rid of it. Thanks
Rocket Scientist
Could I slip in rubber gromets between the 2 13mm bolts? Also my clutch is going and I can hear every sound of my clutch through this shifter. The shifter is acting as a microphone for the clutch.
Hitsquad Ninja
hmm i have the sfr lever as well, but never had any rattling associated with it. although i do not have a real short throw shifter like your 944 racing one so it is probably a different situation. good luck buddy
Take note of the way Porsche isolated the shift **** from the shift rod... large rubber insulators and probably also the weighty OE **** seem to be necessary to dampen the vibrations. I tried in vain to silence the godawful noise but eventually returned to the OE shift lever and **** (with shortshift at the tranny).
Good luck.
Good luck.
Well, I tired lots of stuff to make it not as loud. Right now, I have the thickest piece of rubber in there so it fits and still get the noise. I just gave up on it and deal with it, can't beat the feel. I also bought the short shift for the tranny but still haven't had the time to put it in.
Defending the Border
Rest In Peace
Rest In Peace
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
Installed my SFR ssk and after two Malibu canyon runs where the short shift help make up for my little 26/6 turbo powerband, I am verrry pleased. The Glendora run before the install I was digging 3rd out of the bottom of the pass foot well, j/k. Even shifting without the **** or boot installed was very smooth.
No rattles, OE shift ****, Alan Gunn shift boot, good to go.
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
i too have a rattle in the shifter, its much better now but the fix is a bit strange.
i switched to a boxster shift ****, a bit lighter than the stock one.. and yes i think the weight
of the stock one keeps it from rattling... but, this spring i installed a sfr catback system. when i did this, i moved the clamps to the exhaust mounts on the torque tube. just moved them
an inch or two... most of my rattling is gone now.. i think it was a harmonic vibration around 2800 rpm.
(about 63mph) in 5th... you might want to experiment with moving these.. also check the
rubber parts of the exhaust mounts.. i had one that was pretty bad. i'm replacing it this winter..
good luck
buckshot wi
good luck
buckshot wi
