Need help with late 944 gauge lights quick!
I was installing Flaming Eyes LED lights on my 944 just now, i have everything hooked up correctly by the three slots for the lights no longer work now. I changed the connectors around, then replaced the bulbs in the sockets to see if it was a problem with the wiring, and the bulbs do not work either. Has anyone had this problem before or know how i can fix this? All other lights on the gauge cluster work (such as the warning lights), just the lights that illuminate the actual dials no longer work.
False Alarm. Just got it working...i think the copper strip on the contact sheet was worn, i only turned the bulb holder about 3/4 of the way and now everything works perfectly. Almost gave myself a heart attack there!
Ill edit this thread with a ton of pictures with my progress on the car later...
