Clunking noise from left rear 944S2 CAB
Old 10-06-2004, 10:53 AM
cdahl1927
7th Gear
cdahl1927's Avatar
Default Clunking noise from left rear 944S2 CAB
I am experiancing a clunking or knocking noise from the left rear of my 944S2 CAB. Seem to be coming fom the wheel area. I have replaced the CV joints and axles on both sides. Seems to happen at start up speeds and seems to go away as speed increases or after car has been driven for awhile. Sometimes will go away if I barke hard after startup. Any ideas where to look next.
Old 10-06-2004, 01:19 PM
944_S_TYPE
944_S_TYPE's Avatar
Wheel bearings? Hmmmm. Just a thought? Or mabyee a parking brake shoe?
Old 10-06-2004, 02:16 PM
Peckster
Peckster's Avatar
Check to make sure the nuts on the CV units are tight. They often loosen by themselves
Old 10-06-2004, 02:28 PM
deni durrell
deni durrell's Avatar
someone should do a search and see how many times "clunking" comes up.....
Old 10-06-2004, 02:30 PM
Travis - sflraver
Travis - sflraver's Avatar
My vote goes for the CV joints
Old 10-06-2004, 02:32 PM
daniel951
daniel951's Avatar
sounds like cv joint but since u replaced them already makes me wonder. Try checking over your work to make sure everything installed right and check to see if the bolts are tight
Old 10-07-2004, 12:52 AM
Luis de Prat
Luis de Prat's Avatar
A plain clunk sound may simply be due to the rear brake pads being worn to the point where they shift within the caliper upon hard acceleration. My guess is that you don't have the stock brake dampeners in the rear brakes? Little adhesive thingies that keep the pads static.
Quick Reply: Clunking noise from left rear 944S2 CAB
