speed & reference sendor plug capacity
The plastic on my speed and reference sendor upper male plugs is toast.
To replace these plugs with molex or similar connections, what elecrical capacity, gauge, etc. should I use?
It's merely a sawtooth wave from magnetic sensor, anything you use will be fine. Current is negligible and voltage goes to around 2.5V, 3V max.
Sam
Sam
So a 3-pin molex or similar plug connector with some heat shrink tubing would be OK?
Lots of us have had problems with speed and reference sender connections on our 15-20 year old cars, so I want to fix this once and do it right.
Any suggestions you have for a good connector plug would be MUCH appreciated!
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
