just washed it..alternator light
Old 09-24-2004 | 10:46 AM
nineeagles's Avatar
nineeagles
Default just washed it..alternator light
Just washed the car and started it and the alternator light won't go out unless I rev the engine above 3 grand......I am hoping something just got wet and will be OK when it dries....new alternator last month....
Old 09-24-2004 | 11:15 AM
Porsche-O-Phile's Avatar
Porsche-O-Phile
Probably so - don't panic yet. Give it a day or so and if it still does it, then troubleshoot.
Old 09-24-2004 | 01:02 PM
dualblade's Avatar
dualblade
is the voltage ok?
Old 09-24-2004 | 01:03 PM
nineeagles's Avatar
nineeagles
I don't have a voltmeter in mine and haven't had a chance yet (working) to check with a meter....have to wait until afterweekend to check it.....
Old 09-24-2004 | 01:07 PM
pete944's Avatar
pete944
Check to see if the belt is tight enough. If not it may be wet and slipping slightly.
Old 09-24-2004 | 01:15 PM
Dave951M's Avatar
Dave951M
How old is your alt belt? If it has some age on it, it might have developed that "glaze" and not have the same friction characteristics as a new one.
Old 09-24-2004 | 01:32 PM
Macfreak007's Avatar
Macfreak007
Take a mutilmeter to the batt terminals when the car is off, should read somewhere around 12.5v dc. Then start the car, if the voltage drops the alternator is not charging, I've been there, just last week, probably should be okay when you let it dry out. Try not to get the engine bay wet nexti time, there are tricks to that, but i have learned the lesson about washing the engine.
Old 09-24-2004 | 01:54 PM
IceShark's Avatar
IceShark
Besides belt problems there is a little blue "exciter" wire. There is a 2 prong white molex plug up at the top of the fireawall on the left side of the engine bay. One wire is the blue exciter and the other is a larger red wire that is the starter solenoid trigger.
The exciter wire runs though the starter/alternator harness to the alternator. Here is more than you would ever want to know about what the exciter wire does:
http://www.audiurquattro.de/ralf/inf...Alternator.pdf
I'd first dry out the engine bay but that may not solve the problems if you run the engine before everything is dried out. It took me a month and many hundred dollars to replace all the sensors that went south when I washed my engine bay. It was quite the nightmare.
As it sounds like you just washed the outside of the car I hope you have an easier go at solution.
Old 09-24-2004 | 05:07 PM
dualblade's Avatar
dualblade
wow ice, that sounds like it really sucks!
Quick Reply: just washed it..alternator light
