clutch work
clutch work
hey does anybody know any tricks to get the drive shaft back father so i can get my clutch houseing out the shaft is blocking it. this is the last thing i need to do before i just start to slap in the new parts and put everything back together. please hekp if you are able thanks Ray
u are to rotate the drive shaft i think 180 degrees to clear it. just turn it all thew and it should slide out. U still have to get off all the bolts on the Bell housing before u can put the new parts in. I also hope u have a cheese head to get off those bolts on the Pressure plate and flywheel.
