quickie, CV axel bolt size is (not) M12
triple-square, cheeshead, whatever... TIA, you guys.
Last edited by deni durrell; 09-17-2004 at 05:54 PM. Reason: CV bolt are M8 not M12... Now to find a good socket
those cv axle bolts strip pretty easily if the tool doesnt go all the way in so make sure nothing obstructs the tool. Also if it is anything to you i replaced my cv bolts with a regular allen bolts which are stronger, you dont have to use the same ones that came on the car just make sure they are high grade.
