Questions....
"To me, it's always a good idea to always carry two sacks of something when you walk around. That way, if anybody says, 'Hey, can you give me a hand?,' you can say, 'Sorry, got these sacks.'"
LMAO!!!!!
LMAO!!!!!
You can tilt the roof like this (Look at the first pic in the thread):
https://rennlist.com/forums/showthre...l+sunroof+tilt
I don't know if they are meant to do this, but you can.
Originally Posted by Antonioali
gears are stripped, i do have new gears but the cable is a mess so im going manual.
To fix the cable unbolt the sunroof motor assembly (the whole unit, dont unplug anything), its three 10 or 12 mm bolts. Youll then see right away where the cable feeds into, its basically a hose that runs up the pillar. Feed it in till it stops (only an inch or so), the stop is it hitting the main drive gear. Using a socket, turn the LARGE nut thats on the front so that it feeds the cable in another inch or so. Bolt the unit back into place or prop it up somehow.
Then hop into the car, hold down the middle microswitch, the one thats behind the interior dome light, and push the sunroof button so that it feeds the cable into the hose itself. Stop feeding it frequently to check to make sure the cable is feeding in straight and doesnt have a kink forming. Feed till it stops itself. Voila cable is fixed. If the switch wont feed it in, keep cranking that one bolt with a socket and driver.
Then follow the instructions on clarks-garage for the gears. When youre at the point where you have to mark the lift arms for their position, when theyre held into the sunroof tracks at the elbow (youll know the part I mean when you get to it) double and triple check all that. The first time I did the gears, I didnt align one of the arms properly, so it stripped the gear again. No big deal, I know the routine now so itll prolly take me half the time.
All things considered, it is a pretty well designed system considering it can tilt the roof when im cruising at 120MPH, and it has the precautions built in that is has.
Originally Posted by claw
The electric tilt locks even when opened. Does the Manual? Could be alarming at speed if it doesn't.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Maybe one day ill convert to manual, but that wont be when my car is my daily. If I do remove the electric system, itll be because weight is a concern, and I have already removed A/C, rear seats, etc etc etc.
Originally Posted by tifosiman
I just want to make certain that people understand that I'm not smoking the crack. ![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
