Another... 968 10 speaker stereo question
Fellow Rennlist Audiophiles
I'm about to start upgrading the system in my 968 and I note that there are seemingly 2 small amplifiers under the front seats that are fed by line level inputs from the receiver.
My question -->which part of the system do these various amps power? Does one amp power the front speakers and the other the rear, or does one power the passenger side and the other the driver's side. It isn't ALL that important and no doubt I can figure it out on my own when I start taking things apart, but it would be nice to know up front.
Thanks,
Phil
----------------update to above question-------
After pulling the seats out again...
In my car the amp on the passenger side sends its output to the front speakers and of course the drivers side drivers the rear speakers. From an input perspective the RCA connections coming from the back of the amp will dictate left vs right, front vs back.
Phil
Thanks,
Phil
Phil
Phil,
I have the 10 speaker setup on my S2. I may need a few parts. If you are upgrading, and interested in selling some of the amps cheap, please PM me.
Mine takes a while to heat up. I get more sound from one side, then after about 20 minutes the other kicks in. If I could swap in a used part and correct the problem, life would be even grander.
