Where to get a 944 hub adapter for 930S steering wheel?
Hey guys. I came across the 930S wheel that we kept when we sold my wife's 78 SC. Where can I get a hub adapter so I can use it in my 944. Already have the same wheel in the 911 so I need to do something with this one.
Thanks!
Thanks!
It should be the same. I did need to use the turn signal canceller from my old steering wheel. I believe the difference on the 911 is the location of the canceller(right instead of left or vice versa).
Pete:
The splines on the hub adapter for the 911 that is attached to the wheel are larger in diameter. I found that out when I pulled the stock wheel off. I figured they would be the same.
Thanks for the replies guys and girls
