Screwed - Cannot Open Passenger Door
Old 09-12-2004, 02:39 PM
PeteL
Got Nothin'
PeteL's Avatar
Default Screwed - Cannot Open Passenger Door
I was changing door handles, today. Somehow I managed to get something bound up. I cannot open the door using either the Door Handle or interior handle. Outer is stuck, cannot move the lever. The lock is down, and I cannot get it to the unlocked position. I don't believe I am the first moron to do this. I need help, or I am going to get the jaws of life.
Old 09-12-2004, 02:44 PM
Yabo
Yabo's Avatar
Probalby not the BEST option, but what I would probably do is lower the window completely, stick a slim jim down there,, and start yanking on everything!
Old 09-12-2004, 02:47 PM
PeteL
Got Nothin'
PeteL's Avatar
Been screwing around with that. No luck yet. I was able to pull the interior door panel back to see the bottom of the lock arm, can't get it to move.
Old 09-12-2004, 02:54 PM
83na944
83na944's Avatar
No, Pete, you're the first.
Seriously, it sounds like you'll need to remove the inner door panel and try to unlock the door.
Tough situation. Hopefully someone will have specific info for you.
Good luck.
Old 09-12-2004, 02:56 PM
PeteL
Got Nothin'
PeteL's Avatar
I am not sure I can get the whole panel off. Will try that.
Old 09-12-2004, 03:03 PM
PeteL
Got Nothin'
PeteL's Avatar
OK, the whole panel cannot come off since some of the screws are blocked. If I can trip the lock, the door should open, but I need to be able to separate the outer door handle from the lock mechanism with extremely limited access.....
Yabo
Yabo's Avatar
to get to all the screws that hold the panel on, youll probably have to remove the seat... D'oh! Although hopefully you can get to them by moving the seat back and fowards.
Old 09-12-2004, 03:12 PM
Chris_924s
Nerd Herder
Chris_924s's Avatar
remove the passenger seat and race it..
is it possible tha little plastic piece broke- you know, the weak part of the link? Is the lock stud stuck inside the door panel?
Old 09-12-2004, 03:14 PM
PeteL
Got Nothin'
PeteL's Avatar
All the parts are there, and together. It is just that I must have gotten the lock mechanism and door actuator tangled. They are bound and I cannot clear them. It was stupid, and now I am being punished.
Old 09-12-2004, 05:16 PM
KuHL 951
Hey Man
KuHL 951's Avatar
Sounds like you connected the lock accuator(plastic rod) 'behind' the finger release lever that opens the door. You need to pop the round end off the socket, flip it up and forward and reconnect. You're in a fix since you can't get the door panel off. I did the same thing last month but luckily tried the finger pull first with the door open. A slim jim on these cars works front to rear but if it's jammed I'm not sure it would work at all. Good Luck, this could be a tough one.
Edit: If you remember where that plastic rod connects you might be able to pop it off the ball if you have something thin and rigid enough to use for a lever with the window up. Just a thought
Old 09-12-2004, 05:40 PM
PeteL
Got Nothin'
PeteL's Avatar
I think that is exactly what I did. The anti theft plate makes getting to that little rod tough, but I think you are on to something. Will give it a go...need more beer.
Old 09-12-2004, 05:45 PM
KuHL 951
Hey Man
KuHL 951's Avatar
Beer always helps. There is no metal that can overcome the power of beer!
Old 09-12-2004, 06:37 PM
PeteL
Got Nothin'
PeteL's Avatar
So true...I am walking away from it for now. Too pissed to think..I will break something, or beat a child (that is a joke!) (The child part)
Old 09-12-2004, 06:56 PM
Serge944
Serge944's Avatar
I thought this thread was about somehting useful
(special thanks to fr wilk)
Old 09-12-2004, 09:21 PM
PeteL
Got Nothin'
PeteL's Avatar
Well that helped.... NOT
Quick Reply: Screwed - Cannot Open Passenger Door
