Ignition coils? What do you use?
1 Post
I went with the Jacobs Omni Magnum set-up and Jacobs 8mm wires. It uses the old coil for the timing and boosts the spark going to the distributer with direct juice from the battery. Right now I'm using NGK plugs gapped out to .052, but I'm casually looking for the solid Bosch plugs (directions caution against using platinum or other exotics). Seems to run smoother, but haven't dynoed for improvement.
