How is the rubber wing held onto the glass hatch?
It is held on by a couple screws, and some 6mm cheese head bolts. I think you have to remove the trim to get the wing off (somebody correct me if i am wrong), and that involves making a U shaped screwdriver head. I took a dremel and took the widest head screwdriver i had, and cut a notch out of the middle. The nuts for the trim require this "special tool"
You will know what i am talking about when you take a look. The wing is not hard to remove.
You can use a power screwdriver - CAREFULLY in one notch or the other and rotate it enough slowly that way until you can insert the flat part of the screwdriver blade into the slot spanning both sides.
