Where to jack and block to remove 4 wheels?
Old 09-08-2004 | 06:28 PM
jamiejim's Avatar
jamiejim
Default Where to jack and block to remove 4 wheels?
I need to remove all 4 wheels at one time to get them refinished. Where is the best/correct place to jack on a 944? Do I use the jack point, jack up one side, block it, then jack the other side? Also, where is the best place to put the stands? I only have 2 jack stands, can I just use wood blocks under the axle? I just want to be sure I don't do any damage during this process. Thanks.
Old 09-08-2004 | 07:05 PM
RMills944's Avatar
RMills944
Look just inside the rocker behind the front wheels and infront of the rears. There is a rubber pad behind the front ones - use that. ON the back, you see a small rectangle of steel - use that. These are both right along the bottom edge fo teh body panel. I did this a few weeks ago and it worked great!
Old 09-08-2004 | 08:31 PM
Don 944 LA's Avatar
Don 944 LA
Old 09-08-2004 | 09:16 PM
tcmdocs944's Avatar
tcmdocs944
There is also a write-up on clarks garage.
Be very very careful. This was one of the scarier things I have done on the car. Left side on jackstands, center jacking the whole right side is a nailbiter to say the least.
Just as scary getting it down.
For my early I used the front 'backup' jackstand points placing them just on the other side of the control arm bushing (towards center on beam).
Old 09-08-2004 | 09:24 PM
jamiejim's Avatar
jamiejim
Thanks for all the info. Supposedly my neighbor is getting a hoist installed in his garage, maybe I'll wait for that.
Old 09-08-2004 | 09:25 PM
Rich Sandor's Avatar
Rich Sandor
The trick is to bring it down super slow and move the jack stands at the last 1/4 inch of clearance to make sure there are 100% where you want them. Just do everything slow.
And don't crush any brake lines!
Old 09-08-2004 | 09:26 PM
tcmdocs944's Avatar
tcmdocs944
Originally Posted by jamiejim
Supposedly my neighbor is getting a hoist installed in his garage.
OOOOOoooo I hate guys like that!
Quick Reply: Where to jack and block to remove 4 wheels?
