Wide band and headgasket
which is the best head gasket to put on a modify car. I see that guru had the ultimate head gasket or wide fire or porsche. Your input will help
Also if i get a wide band do i still need the arc2 if not it is for sale let me know thanks
after doing some research i am going with danno's ultimate head gasket after looking at some of his reports. but i am still confused about the wide band if i need a display or do i just set it and forget it kind of deal. Also do i ditch the arc2
If you get a wide band you can ditch the ARM1 if you have it because the wide band monitors your A/F ratio better then the ARM1. You will still need the ARC2 since that is what you use to tune the car.
The SAFC is an option and there are some vendors who sell digital MAF stuff. I am not familiar with any of these I skipped that and went straight to a stand alone. If you do a search on the turbo board you should be able to find out what your options are.
