well it looks like a headgasket
i am going to fix it then decide what i am going to do with it. i was thinking about purchasing a wb02 so i don't have to worry again about this dam headgasket deals. Please someone give me the cheapest place and what will i need to get it.
look i finally hit my 1,000th post YAYAYA!!!
One sad thing is if i get rid of the porsche then my room would look weird. I have my whole room full of models and pictures of porsches
I have a Zeitronix- pretty cheap (especially with the group buy), but I have yet to test it.
I feel your pain though! I blew a headgasket, replaced the motor intsead (found one with a MAF/big turbo for cheap), then 2 months later I blew another headgasket the same day the motor was finished being installed, then fixed the headgasket myself in my college apt parking lot (took 3 months...), then when I was finally done, I broke a piston on the test drive. The original problem was the wastegate, which was in backwards the whole time. I just didnt have enough common sense to see that 30lbs of boost meant faulty/backwards wastegate. I now have a 3rd motor in, and my wastegate is fixed and nearly all issues are taken care of.
Believe me, I KNOW its frustrating, but get the car fixed properly, get a wideband, and tune it properly! You can get a wideband for under $500...
-Randy
-Randy
Yeah I looked at the Zeitronix, iff I didnt have the gauges already I would consider it, but the voltage range does not work with the Link Gauge, only the tech edge does...
anyone has the website to order and exactly what do i need. just the display or a new 02 sensor ??? not sure . Randy seems like u been through alot of **** too.
to tune with a wideband you are going to need the whole kit plus a laptop so you can datalog air/fuel vs. rpm. I have a Zeitronix and its very easy to use.
i have a laptop so that isn't a problem
so is the only thing then for $279 on the website
Zt-2 the most affordable Wideband Air/Fuel Ratio Meter
Only $279 including the Wideband Oxygen Sensor
except do i need a display becauase the price jumps up to $379
