Front Coilover install (PICS!)
Old 12-22-2004, 12:38 PM
  #46
bader$
bader$'s Avatar
Originally Posted by dave120
If you put 300# on the front with stock torsion bars, it's going to understeer badly. Some guys on here actually use an even bigger 29mm torsion in the rear, but 28 seems pretty balanced with my current setup of sway bars and shock stiffness.
My other setup was 200# up front with stock torsion bars and full stiff Konis in the rear, and it was balanced perfectly. I have those 200# ones for sale if you want them. I also have the aluminum spacer that will change them from 1.25" drop up front to about .25" if you don't want to drop it much.
Will those work on a 88 944s with factory struts, and are they the ones that lower the front 1" or so? If they will work how much do you want for them?
Old 12-22-2004, 12:44 PM
  #47
RMills944
RMills944's Avatar
Palsma cutter... lift... what do you ask for at Christmas time???
PS. I like the truck int he background in the one pic too!
Old 12-22-2004, 03:52 PM
  #48
dave120
dave120's Avatar
I sold them a while ago, sorry about that. Paragon Sells them for around $100 or so I think
Quick Reply: Front Coilover install (PICS!)
