Early 944 Ball Joint Replacement
My son and I will be replacing the ball joints on his 1984 944. We have reinforced steel arms and the ball joints are bolt ins.
We are trying to find the torque specs for the three ball joint bolts as well as the pinch bolt that locks the ball joint to the steering knuckle.
Appreciate any help....
Fred
Fred
The original BJ has been replaced as it has rivets and need snapped off to replace the joints. So the bolts you have need torqued to the bolt spec needed. And they are most likely SAE not Metric. Just get them good and tight and you will be fine. Use Loctite if concerned. The pinch bolt can be tightened to snug fit. The BJ shaft has a groove and the pinch bolt runs in the groove keeping the shaft from moving up/down. So just get it tight by hand.
The 3 bolts that hold it to teh arm (where the rivets are) you probably don't want coming out. I just torqued mine as far as I could with a 3/8 ratchet and they have been fine since.
Lifetime Member
Lifetime Member
According to the Haynes manual, and these are the values I've used many times -
balljoint to control arm (three per side) 10-12 Ft-lbs
balljoint to steering knuckle (pinch joint) 37 Ft-lbs
Make sure to use hardened bolts and nuts for the balljoint-to-control arm application, as well as hardened washers. The washers are important for properly spreading the clamping forces. Loctite on the threads is a good idea too.
Matt
Matt
