oil change. Stupid bolt!
Registered User
![Angry](https://rennlist.com/forums/images/icons/icon8.gif)
MY BOLT IS STUCK!!!! and I mean hard. I took it in for a change because I didn't feel like messing with it. had a bad day. so when I get the car back about a month ago, there was a scrath on the side!!! so I went in there and I got like 100 bucks for it!! I didnt know I could do that. anyway. now its time for the 924 to get her fluids changed again and the bolt wont come off. The shop was so stupid as to I think he might even have impact hammered it on.......AAARRGGHH!!!!
anyway. I had a friend back where I used to live that recently pulled the oil filter off his neon and started the engine to get all the oil out....WWAAYYY bad idea I know but. Im losing my patience. HELP!
Jake
-I've tried a foot and a hlaf breaker bar. but nothing.
Jake
Campeck Rulez
don't tell us it was that fool on the SRT-4 forums.....
but on the subject of your bolt..PB blaster maybe?(wait..its not rusted......)
AND WELCOME TO RENNLIST!!!!!!
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
First off, get the correct size socket so that you don't round it off. I don't know it off the top of my head but someone else will. Get it with a 1/2 in drive and hook it up to a breaker bar ( very long rachet used for loosening tight bolts).
edit: I just saw that you tried a breaker bar. Maybe you can buy a steel pipe to extend the length of the breaker bar.
actually i think it's 15mm.
the oil pan is soft - i would think that torquing the drain bolt on that tight would have stripped the oilpan, but then what do i know?
remember - righty tighty, lefty loosey
Registered User
WOW. yall are fast!
YES! I GOT IT OFF!!!
along with a spray of warm oil. get this. I put a steel rod on the end of the breaker bar. A tottal of 4 feet! I think I might have broken my oil pan though![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
edit- YES IT WAS!![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
I wrote the wrong thing down. I dont even know if its possible to supercharge a 924 is it?
edit again- Im in bristol.
edit- YES IT WAS!
