** OK final list of all I am having done to my 924s Automatic**
If there is ANYTHING you all can think of that I need to have my guy check over please tell me because I want to make sure when I get this back I have no worries for a long long time. *takes deep beath* ok here it goes:
1. Radiator
2. Coolant
3. Auxilart Fan Switch
4. Thermostat
5. Water Pump
6. V-Belt
7. Mutlti Rib Belt
8. Auiliary Shaft Roller
9. Balance Shaft Tensioner
10. Cam Cap Gasket
11. Timing Belt
12. Camshaft Seal
13. Engine Seal Kit
14. Timing belt Roller
15. Fuel Filter
16.Brake pad (deluxe set)
17. AT filter change w/fluid
18. Air conditioner recharge
19. Oil Pan gasket
20. Tune-up
Am I missing anything?
1. Radiator
2. Coolant
4. Thermostat
5. Water Pump
6. V-Belt
7. Mutlti Rib Belt
10. Cam Cap Gasket
11. Timing Belt
12. Camshaft Seal
13. Engine Seal Kit
15. Fuel Filter
19. Oil Pan gasket
20. Tune-up
if you are changing the oil pan gasket you should change the motor mounts too since they have to be removed $300 for parts. while you are in there you should also change the rod bearings $150 for parts and labor.
Or, you could skip the oil pan gasket for a few years, and replace it when it is leaking, and save yourself $300 now.
Nah. I have the cash. I want to make sure that before I drive this car that I have covered all my bases. Now I know there is a point where one has to say enoughs enough and just drive the car. I just want to make sure I am covering the a-typical stuff right now. I don't mind spending the money to be honest. Peace of mind is a priceless thing
then skip the oil pan gasket. wait until either the motor mounts start to go, or the oil pan starts to leak.
You are spending a lot on labor to do the oil pan gasket. in order to get to the oil pan gasket you have to remove the motor mounts. in order to get to the rod bearings you have to remove the oil pan gasket.
make sure the rest of the car is not a lemon before spending the $$$. Been there, done that. Had 26k into the S2 I paid 11.5k for. Got 14k when it was stolen. Im still hurting from that reaming.
